That's solved the issue, I must have moved a few of the params to the Status menu by accident. Thanks so much for your help.
Sent: 02-07-2026 05:34
Subject: Dashboard parameters becoming read only
Looking at this params file you've some parameters in status and config menus. The status ones default to read-only whilst config menus are configurable depending on the widget hint. Can you try moving specific problem params outside of any menu and see how they behave?
Richard Crutwell
Ross Video UK
Sent: 02-06-2026 21:02
I may reach out to support at some stage. Worth noting the issue has followed when I made a new blank external panel and linked the XML to it. If I enter the Component Editor on a parameter from this file (e.g. text box) and apply changes it becomes read only regardless of what widget hints are selected.
I've attached the entire XML to this post, if you would like the dashboard file too I will send that as a direct message.
Harrison Lawrence
Broadcast Engineer
Lumen8
Sent: 02-06-2026 04:26
I think there may be a red herring here.
The parameters look fine in 9.16, so I suspect there may be a function manipulating them somewhere along the way. Would you be happy to share the project here, or would you prefer to go through Support?
Richard Crutwell
Ross Video UK
Sent: 02-05-2026 08:03
Sure thing, here's a handful of parameters I've noticed are behaving oddly.
Thanks for your help!
<param access="1" maxlength="0" name="SET Light Trigger"
oid="SET_Light_Trigger" type="STRING" value="" widget="default"/>
<param access="1" constraintstrict="false"
constrainttype="STRING_STRING_CHOICE" maxlength="0"
name="SET Layer" oid="SET_Layer" type="STRING" value="NA" widget="default">
<constraint key="NA">Don't Change</constraint>
<constraint key="0">Default (Layer 0)</constraint>
<constraint key="1">Overlay (Layer 1)</constraint>
<constraint key="2">Layer 2</constraint>
<constraint key="3">Layer 3</constraint>
<constraint key="4">Layer 4</constraint>
<constraint key="5">Layer 5</constraint>
<constraint key="6">Layer 6</constraint>
<constraint key="7">Layer 7</constraint>
<constraint key="8">Layer 8</constraint>
<constraint key="9">Layer 9</constraint>
<constraint key="10">Layer 10</constraint>
<constraint key="20">Take Over</constraint>
</param>
<param access="1" maxlength="0" name="SET Asset"
oid="SET_Asset" type="STRING" value="" widget="text"/>
<param access="1" constrainttype="STRING_CHOICE" maxlength="0"
name="SET Colour" oid="SET_Colour" type="STRING"
value="Grey" widget="combo">
<constraint>Grey</constraint>
<constraint>Red</constraint>
<constraint>Orange</constraint>
<constraint>Yellow</constraint>
<constraint>Green</constraint>
<constraint>Blue</constraint>
<constraint>Purple</constraint>
<constraint>Cyan</constraint>
<constraint>Magenta</constraint>
<constraint>Brown</constraint>
<constraint>White</constraint>
<constraint>Black</constraint>
</param>
<param access="1" maxlength="0" name="SET External"
oid="SET_EXTTrig" type="STRING" value="" widget="default"/>
Harrison Lawrence
Broadcast Engineer
Lumen8
Sent: 02-05-2026 05:48
Can you share a snippet from params XML for the parameters in question?
Depending on the Type, Constraint and Widget Hint, the params may behave unexpectedly. They are sometimes attempting to snap to a specific widget type defined. Although it could also be a bug like you say.
Richard Crutwell
Ross Video UK
