Josh,
Yes you can. See the example below. I created a string param in dashboard to feed my XPression scene.
Link the param to a text object in XPression. Make sure "Requery Scene Datalinqs" is checkmarked on this text object.
In each of the subsequent stat fields you can then reference the text object linked to dashboard in a text macro (@TextObject@) to filter the path in your data source.
Matt Zidik
Art Director
