Josh,
Yes you can. See the example below. I created a string param in dashboard to feed my XPression scene.
![](https://higherlogicdownload.s3.amazonaws.com/ROSSVIDEO/MessageImages/87fee466f3d14361ba6035691c020596.png)
Link the param to a text object in XPression. Make sure "Requery Scene Datalinqs" is checkmarked on this text object.
![](https://higherlogicdownload.s3.amazonaws.com/ROSSVIDEO/MessageImages/f6c2deb633894778bf61b8c287b10978.png)
In each of the subsequent stat fields you can then reference the text object linked to dashboard in a text macro (@TextObject@) to filter the path in your data source.
![](https://higherlogicdownload.s3.amazonaws.com/ROSSVIDEO/MessageImages/a996f59e4c9d4b4dbc160d9cc5f8d741.png)
Matt Zidik
Art Director
Sent: 04-29-2024 14:31
Subject: dashboard - playout lower 3rd via Jersey key in xpression
For our baseball profile, I was looking to use one scene for player batting lowers. is it possible for a parameter value coming from dashboard to serve as a jersey key to read rows for batting stats?
Thanks,
Josh
JOSHUA KEAGY
Xpression operator
Blue Ridge 11
