Dashboard to Overdrive shots information
  • 1.  Dashboard to Overdrive shots information
    Posted 02-20-2025 14:33
    I'm curious about the Object "shots" in Dashboard. I see the listener gets different information form Overdrive such as shot name and template name. I'm wondering if there is any other fields available from this object? Example below, thank you!
    if (typeof (retObj.shots) != 'undefined')
          var shots = retObj.shots;
          for (var i = 0; i < shots.length; i++)
             if (shots[i].type == 'onair')
                   ogscript.rename('slug-onair', shots[i].slug);
                   ogscript.rename('index-onair', shots[i].index);
                   ogscript.rename('shotName-onair', shots[i].shotName);
                   ogscript.rename('templateName-onair', shots[i].templateName);
              if (shots[i].type == 'prepared')
                   ogscript.rename('slug-prepared', shots[i].slug);
                   ogscript.rename('index-prepared', shots[i].index);
                   ogscript.rename('shotName-prepared', shots[i].shotName);
                   ogscript.rename('templateName-prepared', shots[i].templateName);
    Lance Miller
