Dashboard - Using external XML data to show info on a Dashboard
  • 1.  Dashboard - Using external XML data to show info on a Dashboard
    Posted 05-05-2026 12:36
    Just trying to enumerate options here....
    Can Dashboard parse xml data from external sources and display the values or act on the values for what I'm calling a HUD display?
    There may be a number of outside devices that my users need to see the status in front of them.  I can easily create the XML files (or whatever is needed) to herd that data to a single location, what I need on Dashboard is a way to have indicators show up when the xml value shows true.  Or in some instances the actual value of the XML tag contents.
    Any assistance is appreciated.
    David Knighton
    Engineer
    NCSC
