James,
I got to it sooner than I thought.
I made the asyncExec as a function
and one day/time case for my open as a function
or alternately as
and fired the two functions in the main body of my task
It played the open I wanted because the day is neither Sunday nor Saturday, and the time was between 8pm & 9pm, but I didn't get to see about it clearing the Xpression layers I need to clear because the pauses don't happen.
Does anything jump out at you?
I realize in my experimenting, I didn't try putting the asyncExec function into my open function---would that have been closer?
Thanks,
James.
This is the ogScript:
function MyExec() {
/*! block id=1444 !*/
ogscript.asyncExec(MyExec);
<block id="1444" type="customcode" x="8" y="18" w="343" CODE="ogscript.asyncExec(MyExec);" />
function open() {
/*! block id=1445,1446,1447,1448,1449,1450,1451,1452 !*/
if (new Date().getDay() == 0)
if (new Date().getTime() > new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),20,00,0,0).getTime() && new Date().getTime() < new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),21,00,0,0).getTime()) { rosstalk.sendMessage("10.253.10.107", 7788, "TAKE " + 1798 + ":" + (1 -1) + ":" + 10);
} else {
} } else { if (new Date().getDay() == 6) { if (new Date().getTime() > new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),20,00,0,0).getTime() && new Date().getTime() < new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),21,00,0,0).getTime()) { rosstalk.sendMessage("10.253.10.107", 7788, "TAKE " + 1798 + ":" + (1 -1) + ":" + 10);
} else { } } else { if (new Date().getTime() > new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),20,00,0,0).getTime() && new Date().getTime() < new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),21,00,0,0).getTime()) { rosstalk.sendMessage("10.253.10.107", 7788, "TAKE " + 1798 + ":" + (1 -1) + ":" + 10);
} else { } }
/*! block id=1461 !*/
ogscript.pause(2250);
/*! block id=1462 !*/
rosstalk.sendMessage("10.253.10.107", 7788, "CLFB " + (1 - 1) + ":" + 0);
/*! block id=1463 !*/
rosstalk.sendMessage("10.253.10.107", 7788, "CLFB " + (1 - 1) + ":" + 1);
/*! block id=1464 !*/
rosstalk.sendMessage("10.253.10.107", 7788, "CLFB " + (1 - 1) + ":" + 2);
/*! block id=1465 !*/
rosstalk.sendMessage("10.253.10.107", 7788, "CLFB " + (1 - 1) + ":" + 3);
/*! block id=1466 !*/
rosstalk.sendMessage("10.253.10.107", 7788, "CLFB " + (1 - 1) + ":" + 4);
/*! block id=1467 !*/
rosstalk.sendMessage("10.253.10.107", 7788, "CLFB " + (1 - 1) + ":" + 5);
/*! block id=1468 !*/
rosstalk.sendMessage("10.253.10.107", 7788, "CLFB " + (1 - 1) + ":" + 6);
/*! block id=1469 !*/
ogscript.pause(3000);
/*! block id=1470 !*/
rosstalk.sendMessage("10.253.10.88", 7788, "MECUT ME:" + 3);
<block id="1445" type="if_dayofweek" x="107" y="17" w="243" DAY="Sunday" TRUE="ID:1446" FALSE="ID:1448" next="ID:1461" />
<block id="1446" type="if_currenttimebetween" x="515" y="44" w="268" TIME1="20:00" TIME2="21:00" TRUE="ID:1447" FALSE="" />
<block id="1447" type="XPression.1_xpression_take" x="770" y="45" w="257" color="#ffc857" TAKEID="1798" BUFFER="1" LAYER="10" />
<block id="1448" type="if_dayofweek" x="284" y="118" w="243" DAY="Saturday" TRUE="ID:1449" FALSE="ID:1451" />
<block id="1449" type="if_currenttimebetween" x="499" y="151" w="268" TIME1="20:00" TIME2="21:00" TRUE="ID:1450" FALSE="" />
<block id="1450" type="XPression.1_xpression_take" x="765" y="168" w="262" color="#ffc857" TAKEID="1798" BUFFER="1" LAYER="10" />
<block id="1451" type="if_currenttimebetween" x="472" y="271" w="268" TIME1="20:00" TIME2="21:00" TRUE="ID:1452" FALSE="" />
<block id="1452" type="XPression.1_xpression_take" x="763" y="290" w="267" color="#ffc857" TAKEID="1798" BUFFER="1" LAYER="10" />
<block id="1461" type="customcode" x="119" y="267" w="343" CODE="ogscript.pause(2250);" next="ID:1462" />
<block id="1462" type="XPression.1_xpression_clearlayer" x="44" y="448" w="243" color="#ffc857" BUFFER="1" LAYER="0" next="ID:1463" />
<block id="1463" type="XPression.1_xpression_clearlayer" x="251" y="451" w="243" color="#ffc857" BUFFER="1" LAYER="1" next="ID:1464" />
<block id="1464" type="XPression.1_xpression_clearlayer" x="457" y="450" w="243" color="#ffc857" BUFFER="1" LAYER="2" next="ID:1465" />
<block id="1465" type="XPression.1_xpression_clearlayer" x="666" y="448" w="243" color="#ffc857" BUFFER="1" LAYER="3" next="ID:1466" />
<block id="1466" type="XPression.1_xpression_clearlayer" x="40" y="566" w="243" color="#ffc857" BUFFER="1" LAYER="4" next="ID:1467" />
<block id="1467" type="XPression.1_xpression_clearlayer" x="257" y="572" w="243" color="#ffc857" BUFFER="1" LAYER="5" next="ID:1468" />
<block id="1468" type="XPression.1_xpression_clearlayer" x="470" y="574" w="243" color="#ffc857" BUFFER="1" LAYER="6" next="ID:1469" />
<block id="1469" type="customcode" x="87" y="675" w="343" CODE="ogscript.pause(3000);" next="ID:1470" />
<block id="1470" type="Carbonite 00:0F:9B:03:D3:AF<br>Slot 0<br>Carbonite_carbonite_cut" x="531" y="687" w="243" MESRC="ME" MENUM="3" />
/*! block id=1481 !*/
MyExec()
/*! block id=1480 !*/
open()
<block id="1481" type="function_MyExec" x="76" y="30" w="243" next="ID:1480" />
<block id="1480" type="function_open" x="68" y="107" w="243" />
/*!!<checksum>b01a18e66e00fcd0f4bbda0a54782296</checksum>!!*/
James Hessler
WAAY (HEARTLAND MEDIA)
Sent: 01-19-2023 15:58
Subject: DashBoard Visual Logic Ands & Ors
Hey James,
Thank you so much.
It will be a little while before I can digest all this and work it into my button---but the fact that what I need to do is possible is great!
Thanks,
James.
James Hessler
Sent: 01-18-2023 10:04
Hi James
asyncExec does not have a visual logic control block but you can use the "custom code" block to execute it. It takes a function name (and an optional delay) as arguments so you would put your main task body in a function and call it.
You would also use custom code to trigger a pause - it takes a number of milliseconds as its argument.
<abs contexttype="opengear" keepalive="true"> <button buttontype="push" height="111" left="47" name="Async Exec" top="81" width="232"> <task tasktype="ogscript">function MyExec() { /*! block id=1005,1004,1006,1007,1008,1009,1013,1014,1010,1011,1012 !*/ switch ( new Date().getDay()) { case 0: ogscript.debug("Sunday"); break; case 1: ogscript.debug("Monday"); break; case 2: ogscript.debug("Tuesday"); break; case 3: ogscript.debug("Wednesday"); ogscript.pause(1000); ogscript.debug("Yes... definitely Wednesday"); break; case 4: ogscript.debug("Thursday"); break; case 5: ogscript.debug("Friday"); break; case 6: ogscript.debug("Saturday"); break; } /*!! <block id="1005" type="switch" x="244" y="230" w="268" VALUE="ID:1004" STATEMENT="ID:1006" statementtag_STATEMENT="0" STATEMENT_0="ID:1007" statementtag_STATEMENT_0="1" STATEMENT_1="ID:1008" statementtag_STATEMENT_1="2" STATEMENT_2="ID:1009" statementtag_STATEMENT_2="3" STATEMENT_3="ID:1010" statementtag_STATEMENT_3="4" STATEMENT_4="ID:1011" statementtag_STATEMENT_4="5" STATEMENT_5="ID:1012" statementtag_STATEMENT_5="6" STATEMENT_6="" /> <block id="1004" type="getCurrentDay" x="10" y="10" w="243" empty2="" /> <block id="1006" type="ogscript_debug" x="564" y="8" w="243" MESSAGE="Sunday" /> <block id="1007" type="ogscript_debug" x="563" y="75" w="243" MESSAGE="Monday" /> <block id="1008" type="ogscript_debug" x="564" y="143" w="243" MESSAGE="Tuesday" /> <block id="1009" type="ogscript_debug" x="566" y="212" w="243" MESSAGE="Wednesday" next="ID:1013" /> <block id="1013" type="customcode" x="817" y="277" w="343" CODE="ogscript.pause(1000);" next="ID:1014" /> <block id="1014" type="ogscript_debug" x="844" y="439" w="243" MESSAGE="Yes... definitely Wednesday" /> <block id="1010" type="ogscript_debug" x="576" y="426" w="243" MESSAGE="Thursday" /> <block id="1011" type="ogscript_debug" x="575" y="508" w="243" MESSAGE="Friday" /> <block id="1012" type="ogscript_debug" x="569" y="587" w="243" MESSAGE="Saturday" /> !!*/}/*! block id=1001 !*/ogscript.asyncExec(MyExec);/*!! <block id="1001" type="customcode" x="185" y="136" w="343" CODE="ogscript.asyncExec(MyExec);" />!!*//*!!<checksum>28faf98de753390b0fcfc9464c2e5eb2</checksum>!!*/</task> </button></abs>
James Peltzer
Sent: 01-16-2023 16:20
I have working visual logic to decide which open rolls depending upon the day and time that isn't alarmingly bulky.
My problem is that I have five tasks; which open?, pause, clear some Xpression layers, another pause, and cut ME3
If the opens are different lengths, this bites me on the undercut.
I've read about Async.Exec scripts (adding a dealy between tasks) but can't figure out where they would go, much less be able to write them.
I'm only assuming the Async.Exec would apply since I want it all to happen within one task.
Could I add your sample to a custom code block and have it do what I need?
I remember reading about a problem with more than one Async.Exec, so I'm not sure about how to address that...include that script snippet in another Custom Code block.
But where? at the beginning of my visual logic?
I want to exit the visual logic when it fires an open and does all the other steps---does a return block on the out side of my last function do that?
I know---so many questions---is there any hope?
Aside from being wary of the time needed to become proficient at JavaScript and therefore hopefully ogScript, I need this to be visual so that coworkers have a better chance of understanding what it does and be able to make changes down the road.
Thanks,
James.
James Hessler
Sent: 01-16-2023 15:52
If you want to learn how to code, the scrips in DashBoard is JavaScript based, and not that hard to get into.
As for the visual logic you need, I never solved that one in VL myself.
Aleksander Stalsberg
Norway
