Hi Guyz, posting my query again as i didnot get any favourable response the previous time. Would be glad if anyone can assist.
MY QUERY
I have an xml file which contains ID, Teamname, TRICODE, Player 1 to 5 names.
I am able to import Teamname data into Dashboard (i am able to import only 1 data from my xml file)
What i want to do is, based on my selection of the teamname from my dropdown list in Dashboard, i should get ALL the relevent players name also in my DASHBOARD.
I will then connect all this to my xpression.
The end result will be that i choose the team name on dashboard and my xpression graphic shows the team name and all the players in that team.
My dashboard codes are
<meta>
<params>
<param access="1" constrainttype="INT_CHOICE" name="TEAMNAME" oid="TEAMNAME" precision="0" type="INT32" value="1" widget="combo">
<constraint key="1">CLOUD</constraint>
<constraint key="2">INFERNAL</constraint>
<constraint key="3">MOUNTAIN</constraint>
<constraint key="4">OCEAN</constraint>
</param>
</params>
</meta>
<abs height="460" left="79" style="bg#buttonbg;bdr#red;bdr:round;" top="64" width="582">
<param expand="true" height="54" left="40" oid="TEAMNAME" top="120" width="154"/>
<button buttontype="push" height="50" left="36" name="GET DATA" top="46" width="152">
<task tasktype="ogscript">var xmlDocument = ogscript.parseXML('TEST INFO XML.xml'); //Parse the XML
var nodeList = xmlDocument.getElementsByTagName("Team"); //Get the tags we want to include in the constraint
var constraintData = []; //Placeholder for the new constraint data
for (var i = 0; i < nodeList.getLength(); i++) //Loop through each tag we found
var node = nodeList.item(i); //Get the node
constraintData.push({"key": parseInt(node.getAttribute("ID")), "value": node.getAttribute("TeamName")}); //Push the key/value pair
if (constraintData.length == 0) //Placeholder if we don't have anything (OPTIONAL)
constraintData.push({"key": 0, "value": "Nothing"});
var constraint = params.createIntChoiceConstraint(constraintData); //Create the constraint
params.replaceConstraint("TEAMNAME", constraint);</task>
</button>
My xml file is
<TeamFile>
<Team ID="1" TeamName="CLOUD" TRICODE="CLD" PLAYER1="RINGOKUN" PLAYER2="TIMA" PLAYER3="JERICHO" PLAYER4="CHICO" PLAYER5="CRAFT"/>
<Team ID="2" TeamName="INFERNAL" TRICODE="INF" PLAYER1="SENMARIE" PLAYER2="TATSU" PLAYER3="GINROU" PLAYER4="MEYER" PLAYER5="PHONICS"/>
<Team ID="3" TeamName="MOUNTAIN" TRICODE="MTN" PLAYER1="USSIE" PLAYER2="HALDES" PLAYER3="YUJI" PLAYER4="NEXUS GREEN" PLAYER5="LILLET"/>
<Team ID="4" TeamName="OCEAN" TRICODE="OCN" PLAYER1="AIM4" PLAYER2="LACON" PLAYER3="AKAINU" PLAYER4="HOSHIZUKI" PLAYER5="FWRK"/>
</TeamFile>
Gaurav
