Hi Evan
To do what you're talking about (2-way communication with your device parameters over HTTP via DashBoard), you will need to go beyond the generic HTTP trigger service and write a listener that can take-in an HTTP request, perform whatever actions you are looking for, and write-back a response.
I do not have an example at the ready that does this with JSON payloads but that would be a fairly straight-forward expansion on an example panel that I do have to which takes-in HTTP requests and returns parameter values.
This panel looks for
http://localhost:8910/OID_GOES_HERE and returns the value as a string. You could expand the panel to include JSON as part of the query string (or even get to a POST with a little more work and accessing the listener's input stream) and write JSON back the same way that this panel is writing back a simple parameter value string.
<abs contexttype="opengear" id="_top">
<meta>
<params>
<param access="1" maxlength="0" name="Device Identifier" oid="dev_id" type="STRING" value="231bf459-000000f9<br>Slot 8<br>SRA-8201" widget="512"/>
</params>
<context contexttype="opengear" id="my_device" objectid="%value['dev_id'][0]%"/>
</meta>
<param expand="true" height="41" left="2" oid="sw_id" right="124" top="5">
<task tasktype="ogscript">ogscript.reload(null);</task>
</param>
<listener autostart="true" buttontype="toggle" delimiter="0A" delimitertype="bytes" height="48" listenport="8910" name="Listen" right="0" style="style:toggleButton;" top="5" width="114">
<task tasktype="ogscript">if (event.isMessageEvent())
var responseText = null;
var byteStr = event.getBytesAsString();
if (byteStr.indexOf('GET') == 0 || byteStr.indexOf('POST') == 0)
var pathStart = byteStr.indexOf('/');
var pathEnd = byteStr.lastIndexOf(' ');
if (pathStart > 0 && pathEnd > 0 && pathStart < pathEnd)
var requestedParam = unescape(byteStr.substring(pathStart + 1, pathEnd));
if (requestedParam != 'favicon.ico')
var p = params.getParam('my_device', requestedParam, 0);
if (p != null)
responseText = p.getValueAsString();
else
responseText = 'Failed to find parameter ' + requestedParam;
if (responseText == null)
responseText = 'Failed to find a parameter';
this.writeString('HTTP/1.1 200 OK\r\n', false);
this.writeString('Content-Type: text/plain; charset=utf-8\r\n', false);
this.writeString('Connection: close\r\n', false);
this.writeString('Content-Length: ' + responseText.length + '\r\n\r\n', false);
this.writeString(responseText, false);
}</task>
</listener>
James Peltzer
