Ok, do you know any other way of getting updated/changin info from a Dashboard into a text list in XPression?
Sent: 03-17-2025 07:59
Subject: Data Source - User Control Datalinqed to Dashboard
Hey Chris, my apologies I just tested myself and I also cannot get dropdowns to work with XML only with table.
Sent: 03-17-2025 07:47
No, should I?
And let's say I want to expose the names to the operator (Home.Name), then I double-click this line?
No matter what I choose the list in the sequencer is empty.
Chris Nicolay Wernersen
Sent: 03-17-2025 07:21
Did you click include parameters names in config?
Sent: 03-17-2025 07:03
Thanks Simon, that's great advice, I was not aware.
As for getting the datalinqed text-list to update in XML mode, is that not possible? The list is just empty in the sequencer. If I turn off xml-mode, then all parameters in the Dasboard are visible in the list.
Sent: 03-17-2025 05:31
Did you know that when you create parameters in Dashboard, if you name them Home.Jersey, Home.Name, or Home.LastName, they will be grouped under a parent node called "Home" in XML mode? The parameters Jersey, Name, and LastName will appear as child nodes within the Home node.
