Another issue is that the data related to datalinqkey in the initial scene is initially incorrect and will become correct after a few seconds. Is this also a problem with 6.5 datalinq
Sent: 11-14-2024 11:44
Subject: datalinq dymanicURL
And any reason why you have not switched to using the ADODB data source in the 10.5 datalinq server to access the excel file?
Sent: 11-14-2024 11:35
Maybe try turning off live update on some of the datalinq's text objects and see if the flickering stops?
Sent: 11-13-2024 21:59
XPression Studio is 10.5, and RSS Datalinq is used in Datalinq 10.5. Datalinq 6.5 is only used for linking Excel, but the dynamic URL Datalinq key is in Excel.
spike C
Sent: 11-13-2024 16:06
You are running Datalinq version 6.5?
Support for the RSS Datalinq source allowing dynamic URLs to be filled with Datalinq keys was added in XPression version 9.0.
Are you running version 9.0+ both your XPression Studio/Prime and your Datalinq Server?
