No problem, pleased it worked.
Sent: 04-19-2024 10:11
Subject: Datalinq Excel error
Thanks simon
I installed the 32bit and its work now
Sent: 4/19/2024 9:25:00 AM
Subject: RE: Datalinq Excel error
Thank you so much for the exclamation points however did you try installing the 32bit driver as I explained?
Sent: 04-19-2024 08:40
Sent: 4/19/2024 6:48:00 AM
You need to install excel.
If you have and it still does not work follow this link;
https://help.loftware.com/lps-kb/content/data%20sources/how_to__install_32_bit_odbc_driver_for_excel_2010_and_later__xlsx_.htm?TocPath=ARTICLES%7CData%20Sources%7CODBC%20Data%20Sources%7C_____8
Although the driver link seems to be dead so try this link;
https://www.microsoft.com/en-us/download/details.aspx?id=54920
