Just to add to this, if you are using newer versions of Exce, for this sharing menu you will need to to File > Options > Quick Access Toolbar and under "Choose commands from", switch the dropdown to All Commands and then look for Share Workbook (Legacy)
Sent: 04-27-2024 19:09
Subject: Datalinq Excel update
I've had this issue too. Sharing the Excel Spreadsheet solved it for me.
You can find this solution by searching google for "Share Excel Spreadsheet"
Select "Review" tab then click the "Share Workbook" icon on right side of ribbon. Then select check mark, to share with all users, option in the popup window.
I attached an image found on google, that shows exactly what I did to solve my issue. Hope this helps you.
Cheers
Steve Szeszycki
XPresssion Operator
Los Angeles United States
Sent: 04-27-2024 06:24
i upload the screenshots for datalinq
i dont know if it shared or no but i read all data from Excel
can i know how workbook shared
TAMER ABDELAZIZ
ONTV
CAIRO Egypt
Sent: 04-26-2024 12:08
Please post screenshots of your Datalinq configuration for the excel sheet.
Also, is your Excel workbook shared?
Sent: 04-26-2024 09:08
Hi Dears,
now when i use text fill attach to datalinq when ever i update any data in text file and hit Ctrl+S its update on-air directly
but
when i use excel when i update any data i have to save and close excel and take scene offline then online again to see the update
is there is a way to make excel update direct ??
i use excel v2016
and mark Live update in data linq option
TAMER ABDELAZIZ
ONTV
CAIRO Egypt
