Sent: 03-07-2024 15:55
Subject: Datalinq in Visual logic
Thank you for all of the effort. I just take a text and I drag it to the position but it just doesn't change.
It seems like I'm doing the same thing. I tried publishing and unpublishing the objects.
Jim Howells
Dashboard Op
Chicago Cubs
Sent: 03-07-2024 14:23
Are you setting it some other way that might be fighting it because I use this method all the time.
Sent: 03-07-2024 14:12
It did not do anything different. It's like Visual Logic doesn't realize the text is a number and just ignores it for Position
I have a new screen shot.
Jim Howells
Dashboard Op
Chicago Cubs
Sent: 03-06-2024 16:28
I see your problem you need to turn this on.
it's off in your picture.
Sent: 03-06-2024 16:24
Thanks for the Replies. I thought that too and tried it. I've even typed a number into a text box and then linked that text to position, trying to remove the datalinq portion. Didn't work. It's like Visual logic doesn't recognize that it's number and ignores it.
Jim Howells
Dashboard Op
Chicago Cubs
Sent: 03-06-2024 16:03
Personally, I would connect your data to text boxes and then connect the text box to the positions you want.
That way you have a visual way to see the data coming in a changing and it makes it much easier to troubleshoot.
Sent: 03-06-2024 15:23
Here are screen grabs
Dashboard Parameters
Jim Howells
Dashboard Op
Chicago Cubs
