Hi Naga, thanks for the reply.
I am doing the same process as mentioned by you.
But just thought of highlighting the issue.
Gaurav
Sent: 09-28-2024 10:31
Subject: DATALINQ IN VISUAL LOGIC
Hi Gaurav, even I had the same issue multiple times, so for its solution I took a separate text object and datalinked it.
Later in visual logic scene objects selecting the new text objects(text property)>>> Text, and used it in place of datalinq block. This fixed my problem. Please try it.
Naga vamsi villa
XPression Designer
