In your JSON Datalinq source, if you switch from "Wait for file change events" to "poll every 1 second".
This is probably too slow for you, but I am curious if it updates on air if you switch to polling.
Sent: 12-01-2024 06:11
Subject: Datalinq keys with datalinq
yes , live update and requery is both checked.
Bam Bahadur Thapa
Freelancer Graphics Designer
Freelancer
Kathmandu Nepal
Sent: 11-29-2024 06:34
Do you have live update and requery checked?
Sent: 11-28-2024 09:41
if you check that youtuhbe video , may be it will more clear, the image is just for countdown for text for (like as your said earlier about widget, i took it from sequencer position) and it working perfectly ,
but the macros in datalinq it not working as like in video , it is updating only once rather then per frame .
Bam Bahadur Thapa
Freelancer
Kathmandu Nepal
Sent: 11-28-2024 06:53
You maybe running into a order of operation issue, visual logic runs after onOnline.
Sent: 11-28-2024 02:04
https://drive.google.com/file/d/1pZKdU41EFxEjkG2TESke2V0VQkAPAi2V/view?usp=drive_link
json file
Hi simon
i check that post but what iam doing is i had a json file which content multiple parameter in it. i had a text object which number change according to framenumber of sequencer from 0-472 (text object name fnum), i have the same 0-472 total parameter in json file
i have another text object which is directly datalinq to json file
i change the macros in datalinq column section,
as per my knowledge now that datalinq column data need to change while play the sequencer and it need to show the json data parameter according to tha fnum value.
but the problem is it is not doing so .
but if i click the set button in datalinq and click ok (without linking or doing anything else) the data is updating according to fnum value
Please find the image below
Video hlink
https://www.youtube.com/watch?v=9tHNSSZywxo
Bam Bahadur Thapa
Freelancer
Kathmandu Nepal
Sent: 11-26-2024 09:30
I discuss something very similar here but using a widget which are global.
You would then link the text object to the widget but you should it will update in real time.
https://rossvideo.community/discussion/remote-sequencer-with-counter-widget
Sent: 11-26-2024 07:42
here is the json file link
i give my try with this idea,
- create a text object that is drive by sequencer position . (basically frame number of sequencer)
- i use that text object as macros in datalinq column.
- it work but not in real time.
as i play sequencer datalinq data update only once. but as i open datalinq and just press ok it update that time.
Bam Bahadur Thapa
Freelancer
Kathmandu Nepal
Sent: 11-25-2024 10:23
Hi!
Do you have the json file (or an offline copy) available? We can try it locally to see if it's just a Datalinq Key format issue.
Flint Gleeson
Technical Support Product Prime - Xpression
