What you should do is have a hidden data field that is linked to data and set to live update.
Then on that item have an onset text script like this;
dim sd as xpSceneDirector
scene.GetSceneDirectorByName("Player Update", sd)
sd.PlayRange(0, sd.Duration)
sd.AutoStop = true
On the scene director you'll want your animation keyframes plus a script something like this at the frame you want the data to update, i.e mid animation;
Dim dataText, dispText as xpTextObject
Scene.GetObjectByName("DATA_PlayerName", dataText)
Scene.GetObjectByName("DISP_PlayerName", dispText)
dispText.Text = dataText.Text
Sent: 08-03-2022 10:14
Subject: Datalinq update in Scene director
I have text that is set to not live update and then a transition that goes over the top while the transition has covering the text I'd like to update the text.
Josh Udvig
CTN STUDIOS - COON RAPIDS
Sent: 08-03-2022 04:42
When you say update, what do you want to change?
I'm going to guess you mean, have a value, play an animation and then a new value is there?
