Having an issue with datalinq receiving data from dashboard.
I want to set up my scenes to be able to select in the seqencer which league to use or home/away team using selections like @League@ @Select Match@ but problem is if i want to turn of the datalinq it will refer it back to something that doesnt exist.
Example:
OID:tx_fixturesHomeTeamLogo@League@[@Select Match@]
When turning the datalinq to static text it will revert images back to the materials tab instead of actually looking at the correct location or knowing as in this case which image to look at so all my logos in the graphics go the the default state.
Any way around this? Would be happy to explain more if needed.
/Andreas
Andreas Olsson
Graphics developer
Viaplay Group
