I'll separate the projects into their own Shows then. Thanks again Garner!
Sent: 04-04-2024 14:08
Subject: Deploy Xpression Project with Script
Good to hear, its not an easy script to figure out.
You will need to separate the projects out into different shows. Having multiple projects in a single show is not a supported workflow.
Sent: 04-02-2024 17:05
Hey Garner,
This worked perfectly! Thank you very much.
A follow up question, if a Show has multiple Projects saved to it (Project1, Project2, Project3) each with their own list of revisions, is there an easy way to call out that specific project file name, or would it be easier to separate those projects into their own Shows?
[Nick] [Kubinski]
[Studio Production Specialist]
[Sysmex America Inc.]
[Vernon Hills] [USA]
Sent: 04-01-2024 17:51
That script adds a bunch of Debug message stuff that you could remove. The things in bold are what you will want to change.
This script deploys the project from the project server AND then loads the project from disk. Those are separate steps. (DeployRevision & LoadProject)
GetShow - this is the name of the show on the Project Server, not the name of the Project that is in the Show.
Sent: 04-01-2024 17:49
dim projServerClient as xpProjectServerClient
dim projServerRevisions as xpProjectServerRevisions
dim projServerRevision as xpProjectServerRevision
dim projServerShows as xpProjectServerShows
dim projServerShow as xpProjectServerShow
dim projServerCat as xpProjectServerCategory
dim projServerStyle as xpProjectServerStyle
dim host, login, pwd, projName as string
dim port as long
'Login Info
host = "192.168.103.63"
port = 8181
login = "admin"
pwd = "admin"
projName = "mcg"
engine.debugMessage("Going to project server for project: " & projName, 0)
engine.GetProjectServerClient(projServerClient)
projServerClient.Connect(host, login, pwd, port)
projServerClient.GetShowsByKeyword(projName, projServerShows)
projServerShows.GetShow(0, projServerShow)
projServerClient.GetShowRevisions(projServerShow, projServerRevisions)
projServerRevisions.GetRevision(0, projServerRevision)
projServerClient.DeployRevision(projServerRevision, "D:\Projects\AFL\")
engine.loadProject("D:\Projects\Project\" & projServerRevision.FileName)
engine.debugMessage("Project Loaded", 0)
engine.debugMessage("File path: " & "D:\Projects\Project\" & projServerRevision.FileName, 0)
engine.debugMessage("Revision: " & projServerRevision.Revision, 0)
engine.debugMessage("Creation Date: " & projServerRevision.CreationDate, 0)
engine.debugMessage("Total Files: " & projServerRevision.TotalFiles, 0)
engine.debugMessage("Total Size (KB): " & projServerRevision.TotalSizeInKB, 0)
engine.debugMessage("Total Size (MB): " & projServerRevision.TotalSizeInMB, 0)
Sent: 04-01-2024 14:04
I'm looking to have a script in Xpression deploy a project from our project server down to our Graphites. Usually we only need to deploy the most recently published revision of each show.
Here's what I have so far, but it's not deploying anything. I know something is wonky with the script, but I don't know enough about VB to troubleshoot it.
dim ProjectServerClient as xpProjectServerClientdim Revision as xpProjectServerRevisiondim Revisions as xpProjectServerRevisionsdim Show as xpProjectServerShowdim Shows as xpProjectServerShowsdim MaxResult as Integer = Revisions.Max()ProjectServerClient.Connect("Host","Username","Password")Shows.GetShow("show name",Show)ProjectServerClient.GetShowRevisions(Show,Revisions,MaxResult)Revisions.GetRevision(MaxResult,Revision)ProjectServerClient.DeployRevision(Revision,"D:\Project Server Deploy")
[Nick] [Kubinski]
