Imagine a game where a number of blank squares appear on the screen under a question, ala wheel of fortune. Contestant starts guessing letter rapid fire up to a max 0f 10 guesses. I have a dashboard that holds 27 buttons per row (A-Z and blank default). As the operator clicks on a given letter it sets Data1 value. Meanwhile the answer text is fed by an excel sheet. So, on OnSetText for the DATA1 field I have the following script.
dim letter1 as xpTextObject
dim letter1Vis as xpBaseObject
dim Data1 as xpTextObject
engine.getobjectbyname("LETTER 1",letter1)
engine.getobjectbyname("LETTER 1",letter1Vis)
engine.getobjectbyname("DATA_1", Data1)
if Data1.text = letter1.Text then
letter1Vis.Visible = true
else
letter1Vis.Visible = false
end if
A simple visibility switch based on whether two data field match. I think I am missing something simple and small. Helping out a fellow designer.
Thanks in advance
Malcolm Thorpe
xpression design
