Hi Ryan
There are several ways to try to get this workflow. One way is to have your own copy of the parameter that you use to display/update the device's copy. You can listen for changes to the device's parameter and, if your copy is being set to the same value as the device's, you don't write anything back to the device.
<abs contexttype="opengear" keepalive="true">
<meta>
<params>
<param access="1" constraint="0.0;100.0;0.0;100.0;1" constrainttype="INT_STEP_RANGE" name="Device Parameter" oid="Device_Parameter" precision="0" type="INT32" value="83" widget="slider-horizontal"/>
<param access="1" constraint="0.0;100.0;0.0;100.0;1" constrainttype="INT_STEP_RANGE" name="My Parameter" oid="My_Parameter" precision="0" type="INT32" value="83" widget="slider-horizontal"/>
</params>
<ogscript element="0" handles="onchange,onload" oid="Device_Parameter">var deviceValue = params.getValue('Device_Parameter', 0); // get the device value
ogscript.putObject('device-value', deviceValue); // store it so you know it came from the device
params.setValue('My_Parameter', 0, deviceValue); // update your display parameter</ogscript>
</meta>
<param expand="true" height="125" left="199" oid="Device_Parameter" top="66" width="458"/>
<param expand="true" height="119" left="201" oid="My_Parameter" top="225" width="459">
<task tasktype="ogscript">if (this.getValue() != ogscript.getObject('device-value'))
ogscript.debug("I updated the parameter");
params.setValue('Device_Parameter', 0, this.getValue());
}</task>
</param>
<label height="48" left="29" name="Device Parameter" style="txt-align:east" top="98" width="152"/>
<label height="48" left="31" name="My Parameter" style="txt-align:east;" top="249" width="152"/>
James Peltzer
