  • 1.  Disable Scenes in Sequencer via Scene Names
    Posted 05-11-2026 17:52
    Hey All,
    We have multiple copies of scenes that are running in playlists throughout a show. I'm looking to create a script that can grab all the copies of a scene by its name and disable all iterations of that scene in the sequencer. Does anyone know if it's possible to get scene names and disable all copies of them from the sequencer via scripting? Thank you for the help!
    Ben Kessler
    New York United States
  • 2.  RE: Disable Scenes in Sequencer via Scene Names
    Posted 05-12-2026 00:36
    This script can run on a Keyboard/GPI shortcut and will find every instance of a Take Item using a specific scene. Depending on the size of your full Sequence, you may want to look in specific Sequencer Groups or at a specific Take Item ID range to limit the amount of items the script has to loop through:
    'declare variables
    dim take as xpTakeItem
    dim scene as xpScene
    dim i as integer
    'loop through all items in the sequence
    for i = 0 to (engine.Sequencer.ItemCount - 1)
    engine.Sequencer.GetTakeItemByIndex(i,take)
    'get take item's Scene Name
    take.GetTemplateScene(scene)
    'change "L3" to whichever scene name you're looking for
    if scene.Name = "L3"
    take.Disabled = true
    end if
    next
    Jeff Mayer
  • 3.  RE: Disable Scenes in Sequencer via Scene Names
    Posted 05-12-2026 05:49
    Hello everyone.
    Here's a slightly expanded version of Jeff Mayer's script.
            'declare variables
            Dim take As xpTakeItem
            Dim scene As xpScene
            For i As Integer = 0 To (engine.Sequencer.ItemCount - 1)
                If engine.Sequencer.GetTakeItemByIndex(i, take) Then
                    If Not DBNull.Value.Equals(take) Then
                        If scene.Name = "L3" Then
                            take.Disabled = True
                        End If
                    End If
                End If
            Next
    Roman Yaroshenko
    chief specialist
    RBC-TV
    Moscow Russian Federation
  • 4.  RE: Disable Scenes in Sequencer via Scene Names
    Posted 05-12-2026 11:13
    These both worked great, thank you all!
    Ben Kessler
