Hello all, I am having a slight problem with a mask dissolving out... (XP v10.7 build 5640 beta)
Currently I have a L3 with an animated bar (prores 4444). I needed to make the bar shorter so I used a mask. When I animate on screen everything seems to work fine. Though, when doing a simple alpha dissolve out animation on the timeline you can see the outline of the long bar (under the mask) as everything dissolves out (almost as if the mask was dissolving out faster than the long bar).
I played around with layer priorities and couldn't figure out why it's doing that.
I'm just curious as to why this may be happening? I've attached some images of what's going on.
Steve Szeszycki
XPresssion Operator
Los Angeles United States
