Hi there, Simon. I upgraded my Designer to v12.5 (BUILD 6128) in November, and now my system doesn't read all my installed fonts.
I tried adding the ones I want to use in the project folder (FONTS) and then restarting the system, and nada. any thoughts?
Fonts are TrueType and OpenType.
Alejandro Galvan
LA36 LOS ANGELES TV ACCESS
Sent: 06-08-2023 10:50
Subject: Don´t see some Fonts from the window system in Xpression
XPression can see OTT and OTF fonts. You need to restart XPression after installation. You can also put them inside your project and they will appear (private) in that project only. This is generally my preferred way to work so I don't confuse licenses between different clients.
