Hi Ryan,
You will need to handle this through an openGear card. There is no output format conversion on Ultrix Carbonite.
Alternatively, Ultrix now has format conversion capabilities on HDX and MODX boards, unfortunately also only on inputs (and a license is required). But if you take the 1080p output from Ultrix Carbonite, and physically loop it back into the Ultrix, you can convert the signal to 1080i.
Aaron
