Here I found an example:
<abs bottom="0" contexttype="opengear" left="0" right="0" top="0">
<meta>
<ogscript handles="onmousedown" targetid="move-label">var size = ogscript.getSize('move-label');
if (event.getX() < size.width - 10 && event.y < size.height - 10)
ogscript.putObject('mode', 'move');
ogscript.putObject('position', ogscript.getPosition('move-label'));
ogscript.putObject('offsetX', event.x);
ogscript.putObject('offsetY', event.y);
else
ogscript.putObject('mode', 'size');
}</ogscript>
<ogscript handles="ondrag" targetid="move-label">if (ogscript.getObject('mode') == 'size')
ogscript.setSize('move-label', event.getX(), event.getY());
else if (ogscript.getObject('mode') == 'move')
var origin = ogscript.getObject('position');
var offsetX = ogscript.getObject('offsetX');
var offsetY = ogscript.getObject('offsetY');
ogscript.reposition('move-label', origin.x + event.x - offsetX, origin.y + event.y - offsetY);
}</ogscript>
</meta>
<label height="60" left="40" name="Moving and Resizing using Click and Drag" style="txt-align:west;size:Bigger;" top="40" width="620"/>
<label height="20" left="40" name="Click and drag the box to move or resize it." style="txt-align:west;" top="100" width="1100"/>
<abs height="116" id="move-label" left="30" style="bdr:etched;bg#navigationbg;" top="330" width="215">
<label bottom="6" left="4" name="<html><center>Click and drag in the square to move it<br/>Click and drag on the bottom right corner to resize.</center></html>" right="3" style="txt-align:center;" top="5"/>
<abs left="633" top="371"/>
Nicolás Noé
