Hi Natalie
My guess is that you've drawn the drawer container as an overlay on top of your existing panel instead of putting your existing buttons inside of it - if you do this, the drawer container covers your existing controls and will prevent you clicking on them.
The correct approach is to put the drawer at/near the top of your panel's hierarchy and then putting your main button panel inside of it (anchored "center" to be the main fill of the drawer container).
Here is an example:
<abs contexttype="opengear" gridaspect="false" gridheight="485" gridwidth="1304" keepalive="false" touch="true" virtualheight="485" virtualwidth="1304">
<drawer bottom="2" left="2" right="2" tabfill="both" top="2">
<abs anchor="west" height="477" name="Utils" width="277">
<simplegrid bottom="2" cols="3" left="1" right="6" top="1">
<button buttontype="push">
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 1 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 2 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 3 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 4 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 5 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 6 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 7 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 8 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 9 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 10 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 11 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 12 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 13 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 14 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Utility Button 15 ');</task>
</button>
</simplegrid>
<abs anchor="center">
<simplegrid bottom="4" cols="15" left="3" right="4" top="52">
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 1 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 2 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 3 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 4 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 5 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 6 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 7 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 8 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 9 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 10 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 11 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 12 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 13 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 14 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 15 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 16 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 17 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 18 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 19 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 20 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 21 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 22 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 23 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 24 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 25 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 26 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 27 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 28 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 29 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 30 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 31 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 32 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 33 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 34 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 35 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 36 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 37 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 38 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 39 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 40 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 41 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 42 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 43 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 44 ');</task>
</button>
<task tasktype="ogscript">ogscript.rename('output-label', ' Main Button 45 ');</task>
</button>
</simplegrid>
<label height="48" id="output-label" left="7" right="5" style="txt-align:east;font:mono;size:Bigger;bg#000000;fg#FFFFFF;look:round;" top="3"/>
</drawer>
James Peltzer
