I'm on a Carbonite Ultra, Vers 7, relatively new to using Custom Controls. I'm trying to set up a custom control that slides the bottom key layer (Key 1, background video) to the right about 20% using a 30 frame transition (smooth start and end) to allow a graphics background element to simultaneously slide in on top of it from the left using an image sequence in another key (Key 2), and then a text dissolve up over that (Key 3). I have everything figured out with the exception of the DVE move on Key 1. I've found the command in Custom Controls to move the key over 20% to the right, but I cannot find what command to enter to have the move happen over 30 frames; it just pops in, already moved over 20%. What command do I need to insert to account for the transition time? Thanks.
Glenn DiTommaso
Technical Director
Dell Technologies
