  • 1.  Dynamic Datalinq images not updating
    Posted 09-24-2023 18:45
    I am experiencing a bizarre issue with dynamic datalinqs, and cannot figure out what is going on.  I have a right side slab with four images.  They are suppposed to dynamically change based on live, real-time data I am getting.
    Unfortunately, the images don't change.  The images in the preview window stay unchanged, and when I take it to air, the images don't change either. However, here's the bizarre thing, if I hit take 2 or 3 times, the image on air changes.  Is there a setting I am missing so that I can see the images change in the preview windown and then go to air that . (And yes, refresh dynamic datalinqs is checked)
    Also, these machines are alway 'hot' so hitting take 2 or 3 times is not a solution unfortunately.
    Adam
    Off the Post Productions
  • 2.  RE: Dynamic Datalinq images not updating
    Posted 09-25-2023 03:45
    Are you using macros or datalinqs to complete the paths, you should ticket the refresh on change.
  • 3.  RE: Dynamic Datalinq images not updating
    Posted 09-25-2023 10:37
    Thanks Red.
    I had the refresh checked but it wasn't working.  I found a "workaround" and It involved some visual logic I had. By disabling it and reworking some configurations, it's working.
    Appreciate the reply.
  • 4.  RE: Dynamic Datalinq images not updating
    Posted 09-25-2023 10:39
    This is the order that the engine runs which may help you figure out your issue as well.
    1. OnPrepare
    2. Collect Datalinqs / Load Video Clips / Load Textures etc..
    3. OnBeforeOnline
    4. Evaluate transition logic (which may include running OnTransLogicScripts)
    5. OnOnline
    6. Visual Logic Runs
  • 5.  RE: Dynamic Datalinq images not updating
    Posted 09-25-2023 12:36
    That's a huge help.  Thanks Red!
