Issue resolved Red.
I forgot to put the default video on the timeline thats why nothing was playing.
Once the default material video was put on a timeline i can now change the material thru Dynamic Material which is connected to USER INPUT CONTROL. And the video plays only once :-)
Thank you always for your prompt advice.
Gaurav
Sent: 02-19-2024 08:12
Subject: DYNAMIC MATERIAL: CONTINOUS LOOP
If i put a default video material and dynamic material path on the same object then nothing plays on the sequencer.
Gaurav
Sent: 02-19-2024 07:57
Try putting a default material on the object set to play once.
Let me know if that works, if not you may need to use some VL or Script.
Sent: 02-19-2024 07:43
Yes, the material is coming from a file path on one of the local drive.
Gaurav
Sent: 02-19-2024 07:41
Is the material coming from a file path?
