Since there are only 4 icons, you could also use a little scripting to make objects visible or not. Make 4 objects that are in the same position. You would place this script on a hidden text object that is tied to the counter for 1 thru 4. This would update live even if you are on line.
dim Icon1, Icon2, Icon3, Icon4 as xpbaseobject
scene.getobjectbynanme("Icon 1",Icon1)
scene.getobjectbyname("Icon 2", Icon2)
scene.getobjectbyname("Icon 3", Icon3)
scene.getobjectbyname("Icon4", Icon4)
if text = "1" then
icon1.visible=true
Icon2.visible=false
Icon3.visible=false
icon4.visible=false
if text = "2" then
icon1.visible=false
Icon2.visible=true
Icon3.visible=false
icon4.visible=false
elseif
if text = "3" then
icon1.visible=false
Icon2.visible=false
Icon3.visible=true
icon4.visible=false
else if
if text = "4" then
icon1.visible=false
Icon2.visible=false
Icon3.visible=false
icon4.visible=true
end if
(I didnt type this on an xpression so double check for spelling/object matches if this doesn't work for you)
Malcolm Thorpe
xpression design
Sent: 05-16-2025 15:48
Subject: Dynamic Materials not resolving path
As Malcolm says, make sure you are using the type suffix, or you could do it via visual logic if you only have so many choices.
You do mention updating on-air, I don't know if just me but I find that if you put the path as a dynamic material it won't update live, but just every time you take the scene offline/online again.
I have solved it in the past by using volatile textures.
For example, in this case I would make a hidden text object linked to your widget. Then in the script events of the text object I would add the following:
dim icon as xpQuadObject
scene.GetObjectByName("Icon", icon)
icon.SetVolatileTextureFile(0,"C:\Your Filepath\Icon" + Text + "_IMAGE.png")
Jake Lew
Access Communications Co-Operative Limited
Regina Canada
