Hi all-
I'm working on a graphic for team standings in a conference. The team names & records pull via Datalinq from an Excel file and are working as expected. What I can't get to work is getting the team logos to change with them via Dynamic Material.
Each team name is a text object in my scene, so I started by trying to use the @TextObject@ in Dynamic Material to insert that team name into my file path, thereby pointing to the correct team's folder to pull the logo. When I take the scene online, all of the Datalinq text updates correctly, but the logos do not change or update until I click a second time on that scene in the sequencer, and then they all correctly appear - but obviously this is after the scene has been online with incorrect logos.
I went back and watched more tutorial videos on Dynamic Material and thought perhaps the TextObject was the issue, so I tested using a %datalinqkey% with one team instead - still pulling team name via Datalinq but putting an OnSetText script on that text object to create a Datalinq Key. When I took the scene online, it worked - the one line using a datalinq key pulled the correct team logo right away.
However, when I went back and changed the remaining lines over and tested it... same issue as before. None of the lines, including the one that had worked in the test, update logos until I click on it a second time in the sequencer.
I'm at a loss at this point - appreciate any suggestions!
Rob
Rob Coons
Director, StudentU
Big Ten Network
