  • 1.  Effect Dissolve TCB
    Posted 11-11-2024 14:13
      |   view attached
    Using Grass terms of tension, continuity and bias for DVE movements, as well as linear, s-linear and curve, I know these settings are not available in the Carbonite. It appears that most movement is an S-linesr fashion.
    This  is your basic corporate 70/30 2box effect with moves for either side to come to full screen.
    Problem I've run into is when moving a 2 box effect with one of the boxes is cropped. It seems that borders and crop are not using the same motion algorithm as size and position. While everything seems to land at the same time, you get gapes during the movement of a cropped image uncropping and coming to full screen while the uncropped keyer is also moving to full size and off screen.
    Michael Minkoff
    Las Vegas United States
  • 2.  RE: Effect Dissolve TCB
    Posted 11-11-2024 14:15
    I will look into it and get back to you.
