Panel: The last entered EFF RATE becomes persistent across all memories with EFF DISS off during panel recall and Attributes / Recall / Effects Duration From Memory on (brown). So, if you built 3 effects, one with 30, one with 50, one with 200, they will all recall with 200, the last rate you entered.
When played through Dashboard, the rate entered displayed in Attributes / Store / Effects Duration becomes the rate for all memories with EFF DISS off during recall and Effects Duration From Memory on.
This persistent rate applies to all memories, all banks, regardless of where stored.
Sent: 11-07-2022 19:15
Subject: Effects time bug?
Is this happening when recalling from the panel or from dashboard as well?
having effects rate set orange on the recall side should make it so each memory uses it's own stored value.
after each recall if you look on the store attributes page is is changing to the correct value there as it was stored in the first place?
