  • 1.  Exception errors in OnPrepare script
    Posted 05-12-2025 16:36
    Good afternoon,
    I have an issue where a segment of my OnPrepare script is throwing exception errors when played back-to-back then unloaded from Studio.  These errors seem to stack, eventually causing Studio to freeze.  Our full screen templates have the option for users to select built-in backgrounds, as well as drop in background animations from ClipStore.  When a clip is dropped in the script grabs the filename from the background's shader layer, truncates the filename, then sets a string variable based on the remaining text.  This is the section that throws the error (screenshot below).  I've included the script, bolding the part that I think is the issue.  It's been suggested that I use a global script, as this is used in multiple templates, but I am unfamiliar with how to use those.  Thank you all for your assistance.
    Select Case txtStyle.Text
       Case = "Normal"
          objBkgd.SetMaterial(0, matBkgdBlue)
          style = "Blue"
       Case = "Breaking"
          objBkgd.SetMaterial(0, matBkgdRed)
          style = "Red"
       Case = "Elections"
          objBkgd.SetMaterial(0, matBkgdElections)
          style = "Elections"
       Case = "Sports"
          objBkgd.SetMaterial(0, matBkgdSports)
          style = "Sports"
       Case = "Custom" 'set background style if custom
          objBkgd.Visible = False
          objBkgdCustom.Visible = True
          objBkgdCustom.ShowInTemplateData = True
          objBkgdCustom.GetMaterial(0, matBkgd)
             matBkgd.GetShader(0, shadBkgd)
          'select custom clip path and theme
          path = left(shadBkgd.FileName, 36)
          path = right(path, 7)
          txtBkgd.Text = shadBkgd.FileName
          txtPath.Text = path
          engine.DebugMessage("Background Path = " & shadBkgd.FileName, 0)
          engine.DebugMessage("Theme = " & path, 0)
          If path = "THEME R" Then
             style = "Red"
          Else If path = "THEME E" Then
             style = "Elections"
          Else If path = "THEME S" Then
             style = "Sports"
          Else
             style = "Blue"
          End If
    End Select
    John Robbins
    Graham Media Group INC
  • 2.  RE: Exception errors in OnPrepare script
    Posted 19 days ago
    do you have the full script?
