If you want to render the actual Sequencer's output back into a scene, then you need the Clip Server option and then use the Server Channel Material Shader feature.
Sent: 10-24-2023 12:43
Subject: Existing Scene Back Into Another Scene
It doesn't sound impossible unless I am not understanding.
Data Pages can be played and they send the data from their pages to the related scene using the same object names.
If not doesn't work then a script that runs on the onOnline of wipe scene and looks at the take item published field data and copies it might be possible.
Sent: 10-24-2023 12:40
Yeah, talking with someone, I do not think what I am asking about is possible.
Garrett Hall
Overtime Elite
Sent: 10-24-2023 12:28
I should have explained more, there is an XPression feature called data pages.
Sent: 10-24-2023 12:26
Yes.......I guess.
Garrett Hall
Overtime Elite
Sent: 10-24-2023 12:20
Data Pages?
