Hi
Yes there is!
This also works for other things in the sequencer where you want to change many items to the same setting.
Select the top item in your export list, hold down shift the click the bottom item. Now hold alt and check the Still Image check box. Let go of alt and click on Still Image check box on another item and all the check boxes will change.
I've used this to change FrameBuffer too for many items.
Simon
Simon Latus
Simon Latus Media Ltd
United Kingdom
