  • 1.  EXPORT TO .mov IN XPRESSION NOT WORKING
    Posted 04-22-2025 05:03
    I am trying to export a scene in xpression thru Sequencer in .mov format using FFMPEG but the exported video cannot be played inspite of showing file size of few 100 mbs.
    I tried importing the .mov file in after effects but getting an error that the file is damaged.
    I have used this feature in the past and it worked perfectly fine but now it isnt working...
    Also now, the video has a  _tmp as a part of file name. e.g: 'TakeItem0002_tmp.mov'
    Anything that i am missing out in exporting the scene into a .mov video file?
    FYI: I am using XPN STUDIO SCE  v11.5 Build 5832.
    Gaurav
  • 2.  RE: EXPORT TO .mov IN XPRESSION NOT WORKING
    Posted 04-22-2025 07:20
    I seem to get the same behaviour on that version
  • 3.  RE: EXPORT TO .mov IN XPRESSION NOT WORKING
    Posted 25 days ago
    Was a solution ever found? I am having the same exact problem. Running Xpression Studio 11.5 build 5832. I tried running ffmpeg 7.1.1 and 8.0.1 and both times my output is not readable and has _tmp in the output filename.
    Jimmy Slaughter
