Hi Everyone,
I've run into a little bit of a head scratcher when it comes to exporting clips from Mira. We iso record several cameras with multiple audio channels and export with the XD Cam 422 MXF codec. Recently the clips have being imported into Adobe Premiere with audio issues. They will give a blip of audio and be silent for several seconds. This will repeat for the entirety of the clip. I contacted support and they did an upgrade and noticed no issues. I did the same export again with the same issues. We use Switch and VLC to look at clips and they are showing up as a .10 second clip rather than 45 minute or so. I'm just curious if anyone else has run into this issue?
We did check the playout channel and everything plays out fine. It looks like it's either an export issue or premiere issue.
Nick Godfrey
