Richard,
Understood. Well there are a variety of approaches. The approach I would probably take is just to simply to declare a function in an <api/> tag that is at the global scope of your panel. Then call said function from the button within your widget. Then if you also wanted to have a button that triggers all screens you would just make a button outside of your widget that calls that function however many times needed with the appropriate argument configurations for each screen. This is what I would recommend for best practice.
Please let me know if you need any further help with this or if you would like to hear a different approach.
Example of another approach could be using GPI triggers(Not how I would do this but could also work).
Antony Giraldo
DashBoard Custom Panel Developer
Ross Video Creative Services | Rocket Surgery Triggering and Control
Sent: 07-24-2025 08:10
Subject: Exposing widget controls
Anthony,
Thank you for the reply. Yes, a widgetdescriptor, communication will be via an HTTP REST API. I am not after specific help with the widget, my question is more generic. Let's assume I get the widget to work as desired (I have already made one for Adder XDIP KVM receivers).
Let's assume widget had two buttons power On and Off, how would I go about having a pair of buttons on the main canvas (not in a widget) that can effectively press the On button on multiple widgets?
Richard Hills
Sent: 07-24-2025 08:02
Hi Richard,
What do you mean by "I am writing a widget..."? Are you writing a <widgetdescriptor/>?
What are using for control over these displays? RossTalk, UDP, HTTP, OGP, a listener, etc...
Until I have a more detailed understanding of what you are doing and what you are trying to exactly achieve I won't be much help.
Antony Giraldo
