  • 1.  Flare Animation on Lower Thirds
    Posted 05-30-2022 19:44
    First is there any way to do a search by key words on the community posts? Thought I would just type in flare loops or lower thirds. Maybe I am just not seeing that capability and you can do that search with keywords.
    Well if not is there any posts that discuss how to do a basic flare on a lower third that travels along the X from left to right?
    Thank you!
    Michele Hampton
    Michele Hampton
    MICHELE HAMPTON
  • 2.  RE: Flare Animation on Lower Thirds
    Posted 05-30-2022 19:56
    watch this video till end you will find what you want
    https://youtu.be/D4VXH6igf5A
  • 3.  RE: Flare Animation on Lower Thirds
    Posted 05-30-2022 20:36
    Ok I figured it out. When in the Sequencer on the Scene Control tab I need to set the Scene Director to Play Mode - Loop. That did it.
    Thank you for helping me brainstorm!!
    Michele Hampton
    MICHELE HAMPTON
  • 4.  RE: Flare Animation on Lower Thirds
    Posted 05-31-2022 08:17
    You can also do it using Continuous Animation on the individual flare GFX, depending on how you're using it. That's my preference for things like news graphics where everything except the flare would become static after the transition in Scene Director.
    Rob Chronister
  • 5.  RE: Flare Animation on Lower Thirds
    Posted 06-01-2022 17:01
    I figured it out now.
    I made a scene director and key framed the animation, but at frame 0 I made the alpha 0. Then move it to key frame 1 and brought up the alpha then went to key frame 3 then 100% alpha. I put a pause at the end of my animation track which loops it back to frame 0 by default. I then had a 120 frame pause at frame 0. Then it would just be at 0 alpha at frame 0 with a pause.
    Michele Hampton
    MICHELE HAMPTON
