Rather than using a datalinq key, could you use a text macro? That way you could focus on the text object (in this case a jersey number).
Malcolm Thorpe
xpression design
Sent: 03-23-2024 20:49
Subject: Focus Template Data - Datalinq Key?
Hi, I've been using the Focus Object By Name global function in the keyboard macros menu to jump to different data fields in a take item. For example, pressing ALT+T to jump to the "Title" object. I have datalinq keys in my scenes for jerseys, but I cannot seem to jump to them via this command, since I assume it is only for published objects. Any way to focus objects for a datalinq key? Would prefer to do this via a script but can't find anything in the SDK that allows this. Running 10.5. Thanks!
Jack Reynolds
