Hey John! It looks like you're not setting the PlayClockRed scene director back to the beginning, only the PlayClockReset scene director. You can use PlayClockRed.Position(0) or PlayClockRed.PlayRange(0,0).
Additionally, I find it better to reset the scene directors when text="40" or text="25" since the play clock might not always hit 0, but it will always reset to one of those numbers. (Also note that I have my red background visibility animating on frame 1 of the scene director, which is how I avoid using two scene directors)
dim sd as xpSceneDirector
scene.GetSceneDirectorByName("PLAYCLOCK COUNTDOWN",sd)
if text="40" OR text="25" then
sd.PlayRange(0,0)
else if text="5" then
sd.PlayRange(0,300)
end if
Having the animation stop is a little more difficult. A quick and easy way would be to set ranges for each second under 5. This is built for a 59.94 system and my animation is 360 frames long. Example below.
sd.PlayRange(0,0)
else if text=5 then
sd.PlayRange(0,60)
else if text=4 then
sd.PlayRange(60,120)
else if text=3 then
sd.PlayRange(120,180)
else if text=2 then
sd.PlayRange(180,240)
else if text=1 then
sd.PlayRange(240,300)
else if text=0 then
sd.PlayRange(300,360)
end if
Hope this helps!
Brishen Thompson
Demonstration Artist & Trainer - Generalist
