Thanks! That worked; what I did was make a text object where I used a clock to fetch the year in VL and then formatted that to display as YYYY to the text of that object. I then positioned that aligned left and added the script above to the date source aligned right.
I made one adjustment: I added this to the visual basic script to convert the date to drop any leading 0s:
Sent: 08-08-2023 09:18
Subject: Formatting Date & Time
You'll need a source for year, in my case I just made a textbox called "Year" where I wrote the year but you could tie that to VL or to a widget with just YYYY.
Then use this script on your text object instead;
dim day, month, year as string
dim yrText as xpTextObject
Scene.GetObjectByName("Year", yrText)
month = split(text, " ")(2)
day = split(text, " ")(1)
year = yrText.Text
Select Case month
Case "Jan"
month = "January"
Case "Feb"
month = "February"
Case "Mar"
month = "March"
Case "Apr"
month = "April"
Case "May"
month = "May"
Case "Jun"
month = "June"
Case "Jul"
month = "July"
Case "Aug"
month = "August"
Case "Sep"
month = "September"
Case "Oct"
month = "October"
Case "Nov"
month = "November"
Case "Dec"
month = "December"
End Select
text = month & " " & day & "," & " " & year
Sent: 08-08-2023 09:15
oh my bad that would actually display this;
August 02,Tue
Sent: 08-08-2023 09:13
I'm sure someone has a better way than this but if you put this onSetText on the text object that's tied to the date field it will display how you want.
year = split(text, " ")(0)
Select Case month
Case "Jan"
month = "January"
Case "Feb"
month = "February"
Case "Mar"
month = "March"
Case "Apr"
month = "April"
Case "May"
month = "May"
Case "Jun"
month = "June"
Case "Jul"
month = "July"
Case "Aug"
month = "August"
Case "Sep"
month = "September"
Case "Oct"
month = "October"
Case "Nov"
month = "November"
Case "Dec"
month = "December"
End Select
text = month & " " & day & "," & year
Sent: 08-08-2023 07:21
Correct; I'd like to change it so it's August 2, 2023 instead.
Steve Trauger
Sent: 08-08-2023 04:53
so its how does the data you are getting look? "Tue 02 Aug"
