General Discussion
  • 1.  GPI-8941
    Posted 06-08-2026 11:39
    Anyone else trying to use the GPI-8941 card?
    Michael Langlois
    Engineer
    CatholicTV
  • 2.  RE: GPI-8941
    Posted 06-09-2026 08:58
    How are you trying to use the card?  What help would you like with it?
    Director, Switcher Product Management
  • 3.  RE: GPI-8941
    Posted 06-10-2026 06:51
    I have a Panasonic AW-RP150G at the shading station for 8 PTZ cameras. The card is to trigger a salvo route on our Trinix to send selected camera to the shade QC.
    Everything seems good, but the execution of the salvo is not always solid.
    If I use a rtr panel to make the salvo route, it is solid. When we use the GPI, not so much. We see the status on the card go from off-on but it does not always make the route, or the wrong route. IE select cam1 and cam2 appears.
  • 4.  RE: GPI-8941
    Posted 06-10-2026 13:06
    Okay sounds like should open a ticket with support.  They can probably have you run some test steps and pull logs when it passes and fails.
    That sounds for sure like either the GPI is not caught by the card and then sending the message to Ultrix or the ultrix is missing the message.
