We are only updating the graphic in ENPS to change the text in the graphic. So, once we have added text into say a fullscreen, and add it to story slug, if we go back into ENPS to edit the graphic to fix a misspelling, it does not update.
This is with the existing graphics that had already been published. To my understanding, this issue started with the lower thirds prior to adding 3 scenes to the graphics package, and deploying. It is now not allowing us to update graphic in ENPS once we have added it to story slug.
It is not affecting the on air product. Instead up updating in Script/ENPS story slug, we have to start it from blank template.
Andre Sanders
Technical Media Producer
WUFT
Sent: 10-28-2023 14:42
Subject: Graphic is not updating after edited in ENPS
How are you trying to get to the graphic to edit it, and are you getting any errors or messages when you try? Is this for new graphics being built after a new revision was published, or is this issue only effecting existing graphics in your scripts. Any chance the scene names of existing MOS items changed in your project before republishing?
Jeff Mayer
