make sure you are on Dashboard 9.15
In the software folder (USB download) you would find:
The Midi device setup folder:
There is a custom panel you can use to configure it to the "default layout" that works with the Xtouch .. but really it just links to standard midi events
you can map your hardware to the same CC and Notes.
here is a link to the MidiDevice setup stuff
https://www.dropbox.com/scl/fi/d810b9e9hc5fxxry65bsy/MIDI-Device-Setup.zip?rlkey=amgmaeajq971pdozm3vca14uz&dl=0
