  • 1.  Hack for sharing - Inverted mask: Slab to Quad for rounded corners
    Posted 10-09-2023 11:32
    Happy Monday All,
    Alphas in Xpression can be a little challenging, and I stumbled across a hack I wanted to share. We use rounded corners on images on a lot of our content, and I figured out a solution where I lean into the texturing flexibility of a quad, but use a slab for the alpha. I discovered a way to invert the alpha by creating a die-cut of sorts with the slab, and wanted to share the win from the effort.
    I've also got some scripting where you can change to value of the rounding with a drop down menu. Only real callout is to see the differences of the Alpha Blending modes of the two layer objects associated with each image.
    Chris Jordan
    Graphic Artist in Charge
    NBCUniversal
    Attachment(s)
    xpp
    Boxes for sharing.xpp   1.28 MB 1 version
  • 2.  RE: Hack for sharing - Inverted mask: Slab to Quad for rounded corners
    Posted 10-09-2023 12:32
    Very cool. I've tried figuring this out too but failed.
    Many thanks!
    Azathoth
    Son of Cthulhu
  • 3.  RE: Hack for sharing - Inverted mask: Slab to Quad for rounded corners
    Posted 10-15-2023 11:38
    THANKS!
    Nicole Schindeldecker
    FERNSEHGRAFIK
  • 4.  RE: Hack for sharing - Inverted mask: Slab to Quad for rounded corners
    MalThePal
    Posted 10-16-2023 12:40
    This is epic. It makes my work so much easier. Thank you.
    Malcolm Thorpe
