I have a DashBoard panel with an editable list of custom control recalls and bus assignments to build split boxes and feed monitor arrays on two MEs and a MiniME on our Carbonite Black, plus hot buttons for various pieces of art, clearing Xpression channels, etc.
I have just added a button (fired by RossTalk GPI from the Carbonite) that will change the background of my split boxes, cut to air, and play one of two animations depending on a toggle button parameter.
If I have two versions of the DashBoard panel open---one for this show, one for the next show---the button no longer works.
Is having two references to the parameter the conflict? or is it the two buttons with the same trigger ID?
I can disable each of the tasks in the button with a toggle parameter (offline vs live,) but I can't think of a way to make parameter not be a parameter.
I have the option to move the button to another panel, but it contains actions I drive from Carbonite that I would rather not be exposed .
Does anybody see a solution?
Thanks,
James.
#DashBoard #CarboniteBlack
James Hessler
WAAY TV (ALLEN MEDIA BROADCASTING)
