  • 1.  HELP - Transition Logic
    Posted 06-29-2022 18:26
    I just can't figure this out.
    I have a premade lower third animation from AE that basically has a orange color slide left to right to reveal a black background.  I created the text in XPression to go on it as well as a mask that helps to reveal the text as the animation moves.
    I created 2 scene directors so that in can effect on and effect off.
    The problem is that I want the next graphic (same lower 3rd different info) to just animate over it.  I don't want a dissolve or a cut.
    All the transition logic videos show the text updating - I want the whole graphic to update (without removing the one on-air).
    I want the next graphic to basically cover the one on-air.
    Is there a way to do this?  I have been playing with different combinations of transition logic all day.
    If there no no way to do in TL - should I be using Visual Logic?  Any examples?
    Thanks,
    ASB
    ASB
    Graphics Designer II
  • 2.  RE: HELP - Transition Logic
    Posted 06-30-2022 04:20
    Tick off animated objects only and tick on incoming scene on top like I have done in the left of this image.
