Thank you for the comment, I think, as of right now, I will leave the value at "0".
My graphic is for soccer games, there are a lot of text objects in the player's roster, score, substitutions, etc.. I should learn more about the workflow with Datalinq and should sort out my workflow. And will start consideration using Dashboard.
Takuya Hoshikaya
Sent: 10-24-2024 15:52
Subject: How many seconds would be reasonable for ADODB Datalinq option to read Excel
If you are not having issues with data refresh, you should leave it at 0. XPression will ask Datalinq to query the database at the time the graphic is prepared for playout (when you hit TAKE in the Sequencer on a take item). Operating like this should work for the majority of systems installs. Typically we only see data refresh issues when the database is very slow to respond to queries (2-3 seconds or higher), or if the XPression graphic has a lot of text objects that run queries (10-40+)
